Aller au contenu principal
Asus Vivobook Flip 14 TP410U Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Vivobook Flip 14 TP410U Motherboard Replacement, Unplug the Power Cable: étape 1, image 1 de 1
    • Unplug the power cable from the laptop and assure that the laptop is completely turned off.
  2. Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the screws: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the eleven 12.8 mm screws from the bottom cover.
  3. Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the top cover (keyboard cover): étape 3, image 1 de 3 Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the top cover (keyboard cover): étape 3, image 2 de 3 Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the top cover (keyboard cover): étape 3, image 3 de 3
    • Flip the laptop 360 degrees. This makes opening up the back cover easier and causes less harm to the components.
    • Insert the opening tool in between the back cover and keyboard.
    • Apply pressure and undo all of the "snaps" that are connecting the back cover and keyboard.
  4. Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the Cables that connect various Components to the Motherboard: étape 4, image 1 de 2 Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the Cables that connect various Components to the Motherboard: étape 4, image 2 de 2
    • Remove each cable connected to the HD audio, Wi-Fi card, and touchpad.
    • Excessive force may cause permanent damage to the cables.
  5. Asus Vivobook Flip 14 TP410U Motherboard Replacement, Unscrew the Motherboard screws and Disconnect the Display Connector: étape 5, image 1 de 1
    • Unscrew and remove the ten 6.4 mm Phillips #00 screws that are outlined in the photo.
    • Remove the connector connecting the front display to the motherboard.
    • Excessive force when unplugging each connector may cause permanent damage to the cable.
  6. Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the Motherboard: étape 6, image 1 de 2 Asus Vivobook Flip 14 TP410U Motherboard Replacement, Remove the Motherboard: étape 6, image 2 de 2
    • Remove the motherboard by pulling the motherboard away from the I/O Ports on the side of the laptop.
    • Excessive force may cause damages to other components in laptop.
Dominic Bento
Membre depuis le 03/22/22
326 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 36
Total : 1,361
