Aller au contenu principal
Asus Vivobook S500CA Screen Hinges Replacement
Ce dont vous avez besoin
  1. Asus Vivobook S500CA Screen Hinges Replacement, Screen Hinges: étape 1, image 1 de 1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Screen Hinges Replacement: étape 2, image 1 de 1
    • Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • It may be helpful to lay out the screws in the orientation in which they are taken out, in order to help remember where they go.
  3. Asus Vivobook S500CA Screen Hinges Replacement: étape 3, image 1 de 1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Screen Hinges Replacement: étape 4, image 1 de 2 Asus Vivobook S500CA Screen Hinges Replacement: étape 4, image 2 de 2
    • Remove 3 (.5 cm) phillips screws around the edge of the hinge. Repeat for other side.
  5. Asus Vivobook S500CA Screen Hinges Replacement: étape 5, image 1 de 1
    • Disconnect the black and white wires from the “Aux” (white) and “Main” (black) ports
  6. Asus Vivobook S500CA Screen Hinges Replacement: étape 6, image 1 de 2 Asus Vivobook S500CA Screen Hinges Replacement: étape 6, image 2 de 2
    • Open the device to access the plastic casing over the hinges.
    • Remove the casing by lifting firmly. This step can be difficult.
  7. Asus Vivobook S500CA Screen Hinges Replacement: étape 7, image 1 de 2 Asus Vivobook S500CA Screen Hinges Replacement: étape 7, image 2 de 2
    • Remove 4 (.5 cm) screws from the hinge. Remove the hinge and follow steps in reverse order to reassemble and complete repair.
Jermaine Carnell
Membre depuis le 01/17/17
107 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Hi.
The Asus X550C set screen (screen + flat cable) is compatible with Asus S500CA notebook? Anybody know response for me? Tks
Rodrigo Rodrigues - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 2,350
