Pièces
Aucune pièce nécessaire.
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
  • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
  • Unscrew the 2 4 mm Phillips head screws by the battery.
Ajouter un commentaire
Remove the panel above the keyboard with a plastic spudger.
  • Remove the panel above the keyboard with a plastic spudger.
  • Once the panel is removed, use the spudger to pry out the keyboard.
  • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
  • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
  • Now you can fully remove the keyboard from the laptop.
  • Place your fingers or a spudger between the front panel and the rest of the laptop.
  • Pull upwards gently to detach the side you are grabbing.
  • Repeat on the other side until the panel easily peels off the laptop.
  • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  • Gently pull the ribbon cable out of its socket attached to the touchpad.
  • You are now able to remove the touchpad.
  • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
  • Unscrew the 4 mm Phillips screw beneath the panel.
  • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
  • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
  • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
  • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
  • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
  • Unscrew the 5mm Phillips head screw that lies just above the D screw.
  • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
  • After finishing this step, flip the laptop over.
  • Everything should now be loose enough for you to start removing the panel.
  • Do not fully remove the panel, for there are still ribbons attached on the inside.
  • Carefully remove the ribbons from the base.
  • Then you can lift the panel to access the components beneath.
  • Remove the 2 4 mm, wide Phillips screws per speaker holding in the two speakers at the lower end of the device.
  • Lift up the speakers to separate from the device.
  • The speakers are connected to the device by a cable. Be careful not to rip this off.
  • Grab the cable by the white connection to the laptop, and gently pull to disconnect.
Nolan Schock
Membre depuis le 14/04/2014
501 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 13-29, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 124
