Aller au contenu principal
Asus X200CA Battery Replacement
Ce dont vous avez besoin
  1. Asus X200CA Battery Replacement, Keyboard: étape 1, image 1 de 2 Asus X200CA Battery Replacement, Keyboard: étape 1, image 2 de 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Battery Replacement: étape 2, image 1 de 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Battery Replacement: étape 3, image 1 de 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Battery Replacement, Battery: étape 4, image 1 de 2 Asus X200CA Battery Replacement, Battery: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
  5. Asus X200CA Battery Replacement: étape 5, image 1 de 1
    • Lift the battery by the tab you removed the screw from.
    • Replace with the new battery, if necessary.
11 autres ont terminé cette réparation.
Jacqueline Collier
Membre depuis le 10/09/17
1 047 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G2, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 29
Total : 6,926
