Aller au contenu principal
Asus X200CA Motherboard and RAM Replacement
Ce dont vous avez besoin
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: étape 1, image 1 de 2 Asus X200CA Motherboard and RAM Replacement, Keyboard: étape 1, image 2 de 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: étape 2, image 1 de 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: étape 3, image 1 de 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: étape 4, image 1 de 1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: étape 5, image 1 de 2 Asus X200CA Motherboard and RAM Replacement: étape 5, image 2 de 2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: étape 6, image 1 de 2 Asus X200CA Motherboard and RAM Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: étape 7, image 1 de 2 Asus X200CA Motherboard and RAM Replacement: étape 7, image 2 de 2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: étape 8, image 1 de 1
    • Lift the motherboard/RAM out from the frame.
7 autres ont terminé cette réparation.
Jacqueline Collier
Membre depuis le 10/09/17
1 047 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G2, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 100
Total : 8,852
