Aller au contenu principal
Asus X200CA-HCL 1104G Motherboard Replacement
Ce dont vous avez besoin
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: étape 2, image 1 de 1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: étape 3, image 1 de 1
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: étape 5, image 1 de 1
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: étape 6, image 1 de 1
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
Svetlana Pimentel
Membre depuis le 10/17/17
201 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 17
Total : 392
