Aller au contenu principal
Asus X200CA-HCL 1104G Speaker Replacement
Ce dont vous avez besoin
  1. Asus X200CA-HCL 1104G Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Speaker Replacement: étape 2, image 1 de 1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Speaker Replacement: étape 3, image 1 de 1
    • Unclip the connector that is located above touch screen
  4. Asus X200CA-HCL 1104G Speaker Replacement: étape 4, image 1 de 1
    • Use tweezers to remove the speaker bar that is located beneath the touch screen.
    • Once removed carefully disconnect the clip to the left of the speaker.
Svetlana Pimentel
Membre depuis le 10/17/17
201 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 12
Total : 285
