Aller au contenu principal
Asus X200MA Fan Replacement
Ce dont vous avez besoin
  1. Asus X200MA Fan Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Fan Replacement: étape 2, image 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Fan Replacement, Battery: étape 3, image 1 de 1
    • Take two rubber caps off the back side of the laptop.
  4. Asus X200MA Fan Replacement: étape 4, image 1 de 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  5. Asus X200MA Fan Replacement: étape 5, image 1 de 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  6. Asus X200MA Fan Replacement: étape 6, image 1 de 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  7. Asus X200MA Fan Replacement: étape 7, image 1 de 1
    • Slide the battery up and out.
  8. Asus X200MA Fan Replacement, Fan: étape 8, image 1 de 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  9. Asus X200MA Fan Replacement: étape 9, image 1 de 2 Asus X200MA Fan Replacement: étape 9, image 2 de 2
    • Unplug the set of wires located at bottom corner on fan.
  10. Asus X200MA Fan Replacement: étape 10, image 1 de 2 Asus X200MA Fan Replacement: étape 10, image 2 de 2
    • Lift up and out to completely the remove fan component.
3 autres ont terminé cette réparation.
Vanessa Garcia
Membre depuis le 01/22/15
1 763 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-24, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 2,368
