Aller au contenu principal
Asus X401A Processor Replacement
Ce dont vous avez besoin
  1. Asus X401A Processor Replacement, Processor: étape 1, image 1 de 2 Asus X401A Processor Replacement, Processor: étape 1, image 2 de 2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: étape 2, image 1 de 3 Asus X401A Processor Replacement: étape 2, image 2 de 3 Asus X401A Processor Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: étape 3, image 1 de 3 Asus X401A Processor Replacement: étape 3, image 2 de 3 Asus X401A Processor Replacement: étape 3, image 3 de 3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: étape 4, image 1 de 3 Asus X401A Processor Replacement: étape 4, image 2 de 3 Asus X401A Processor Replacement: étape 4, image 3 de 3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: étape 5, image 1 de 1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: étape 6, image 1 de 1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: étape 7, image 1 de 2 Asus X401A Processor Replacement: étape 7, image 2 de 2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: étape 8, image 1 de 1
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: étape 9, image 1 de 3 Asus X401A Processor Replacement: étape 9, image 2 de 3 Asus X401A Processor Replacement: étape 9, image 3 de 3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: étape 10, image 1 de 2 Asus X401A Processor Replacement: étape 10, image 2 de 2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: étape 11, image 1 de 2 Asus X401A Processor Replacement: étape 11, image 2 de 2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: étape 12, image 1 de 3 Asus X401A Processor Replacement: étape 12, image 2 de 3 Asus X401A Processor Replacement: étape 12, image 3 de 3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
2 autres ont terminé cette réparation.
Tyler Stiles
Membre depuis le 02/07/17
152 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-4, Wilder Spring 2017 Membre de l'équipe Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 membres
5 tutoriels rédigés
Un commentaire
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 1,834
