Aller au contenu principal
Asus X401A Wireless Card Replacement
Ce dont vous avez besoin
  1. Asus X401A Wireless Card Replacement, Wireless Card: étape 1, image 1 de 1
    • Use a Phillips head #1 screwdriver to remove the eight 3mm screws.
    • Use a Phillips head #1 screwdriver to remove the two 4mm screws.
  2. Asus X401A Wireless Card Replacement: étape 2, image 1 de 2 Asus X401A Wireless Card Replacement: étape 2, image 2 de 2
    • After removing the screws from the underside, flip the laptop over and, using a plastic opening tool, remove the keyboard panel
    • To efficiently remove the keyboard panel, use the opening tool in a prying motion
    • When reattaching the keyboard panel, press firmly until snaps are heard, indicating the panel has been reattached.
  3. Asus X401A Wireless Card Replacement: étape 3, image 1 de 3 Asus X401A Wireless Card Replacement: étape 3, image 2 de 3 Asus X401A Wireless Card Replacement: étape 3, image 3 de 3
    • Disconnect these cables by unlocking the ZIF connectors with a spudger.
  4. Asus X401A Wireless Card Replacement: étape 4, image 1 de 2 Asus X401A Wireless Card Replacement: étape 4, image 2 de 2
    • Using a Phillips Head 1 Screwdriver, remove all screws securing the motherboard to the frame of the laptop
  5. Asus X401A Wireless Card Replacement: étape 5, image 1 de 2 Asus X401A Wireless Card Replacement: étape 5, image 2 de 2
    • Use a spudger to lift up on the ZIF tab and remove the USB/charing port ribbon cable.
    • Use a spudger to release the speaker's bundled cable from the connector.
    • After disconnecting the USB/Charging port board completely, remove and set aside, as it would otherwise obstruct future steps.
  6. Asus X401A Wireless Card Replacement: étape 6, image 1 de 2 Asus X401A Wireless Card Replacement: étape 6, image 2 de 2
    • Peel back the tape securing the cable for the laptop's screen. It is not recommended you disconnect the cable at this time, as you risk damaging the cable.
  7. Asus X401A Wireless Card Replacement: étape 7, image 1 de 3 Asus X401A Wireless Card Replacement: étape 7, image 2 de 3 Asus X401A Wireless Card Replacement: étape 7, image 3 de 3
    • Using the plastic spudger tool, lift up the fan from the frame of the laptop using a prying motion, which will also lift the motherboard
    • As you remove the motherboard, pull it towards the left to allow the ports on the opposite side to slide out easily from their slots.
    • As you lift the motherboard, disconnect the video cable mentioned in the previous step.
  8. Asus X401A Wireless Card Replacement: étape 8, image 1 de 3 Asus X401A Wireless Card Replacement: étape 8, image 2 de 3 Asus X401A Wireless Card Replacement: étape 8, image 3 de 3
    • Identify the wireless card on the underside of the motherboard and remove the 2 screws holding it in place
    • As you remove the second screw, the wireless card will spring up on its own
  9. Asus X401A Wireless Card Replacement: étape 9, image 1 de 2 Asus X401A Wireless Card Replacement: étape 9, image 2 de 2
    • Remove the wireless card along its angle, and insert your replacement card at the same angle.
2 autres ont terminé cette réparation.
Connor Santee
Membre depuis le 02/07/17
149 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-4, Wilder Spring 2017 Membre de l'équipe Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 852
