Aller au contenu principal
Asus X550ZA-SA100603E Battery Replacement
Ce dont vous avez besoin
  1. Asus X550ZA-SA100603E Battery Replacement, Keyboard: étape 1, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Battery Replacement: étape 2, image 1 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 2, image 2 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 2, image 3 de 3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Battery Replacement: étape 3, image 1 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 3, image 2 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Battery Replacement: étape 4, image 1 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 4, image 2 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 4, image 3 de 3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Battery Replacement: étape 5, image 1 de 1
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Battery Replacement, Battery: étape 6, image 1 de 2 Asus X550ZA-SA100603E Battery Replacement, Battery: étape 6, image 2 de 2
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Battery Replacement: étape 7, image 1 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 7, image 2 de 3 Asus X550ZA-SA100603E Battery Replacement: étape 7, image 3 de 3
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
6 autres ont terminé cette réparation.
Tim Linton
Membre depuis le 04/06/17
796 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 29
Total : 6,129
