Aller au contenu principal
Asus X5511M-RCLN03 Battery Replacement
Ce dont vous avez besoin
  1. Asus X5511M-RCLN03 Battery Replacement, Battery: étape 1, image 1 de 1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Battery Replacement: étape 2, image 1 de 1
    • Remove all 4 mm screws using a #00 Philip's screwdriver.
  3. Asus X5511M-RCLN03 Battery Replacement: étape 3, image 1 de 1
    • Open the laptop with the keyboard facing upward.
  4. Asus X5511M-RCLN03 Battery Replacement: étape 4, image 1 de 1
    • Carefully pry up the keyboard cover with your fingers or with a plastic spudger.
  5. Asus X5511M-RCLN03 Battery Replacement: étape 5, image 1 de 2 Asus X5511M-RCLN03 Battery Replacement: étape 5, image 2 de 2
    • Remove electrical ribbons by gently lifting up the tab that is holding them down, then pulling them gently.
  6. Asus X5511M-RCLN03 Battery Replacement: étape 6, image 1 de 1
    • Set the keyboard plate aside. Gently lift up battery to remove it.
3 autres ont terminé cette réparation.
Ryann Easterbrook
Membre depuis le 01/12/17
154 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 2-5, Ruskiewicz Winter 2017 Membre de l'équipe Oakland University, Team 2-5, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G5
3 membres
2 tutoriels rédigés
3 commentaires
Peer review:
Step 1: This step is unclear and seems unnecessary. It should be removed or reworded to be more specific: "Position the laptop with the back cover facing upward."
Step 3: This step is also unclear and seems unnecessary. It should be removed or reworded: "Re-position the laptop with the back cover facing downward."
Step 5: This step is grammatically confusing and should be reworded. Example: "Lift up the tab covering the electrical ribbons. Pull the ribbons gently to remove them."
Courtney Clark - Réponse
Steps 5 and 6 are missing photos so the instruction is not clear.
This was a easy and strait forward repair it took longer to find the tools than to do the repair. The hardest part for me was plugging the flex cables back in as I have a tremor in my hands. the repair took about 10 minutes.
DANIEL HATHAWAY - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 1,597
