Aller au contenu principal
Asus X555LA-SI305041 Keyboard Assembly Replacement
Ce dont vous avez besoin
  1. Asus X555LA-SI305041  Keyboard Assembly Replacement, Keyboard Assembly: étape 1, image 1 de 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041  Keyboard Assembly Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041  Keyboard Assembly Replacement: étape 3, image 1 de 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041  Keyboard Assembly Replacement: étape 4, image 1 de 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041  Keyboard Assembly Replacement: étape 5, image 1 de 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
13 autres ont terminé cette réparation.
Alex Turner
Membre depuis le 09/28/15
1 864 Réputation
3 tutoriels rédigés
Équipe
2 commentaires
Truly useless guide
vic_1199 - Réponse
Could use some more steps on how to removed completely, including the touch-pad.
Can this be revised soon with more steps and pics? Please.
I need to replaced this keyboard because I have some non-working keys.
Frank P. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 45
Total : 8,896
