Aller au contenu principal
Asus X55C CMOS / BIOS Battery Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Asus X55C CMOS / BIOS Battery Replacement, Keyboard: étape 1, image 1 de 1
    • Switch off the laptop and remove the battery.
  2. Asus X55C CMOS / BIOS Battery Replacement: étape 2, image 1 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 2, image 2 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 2, image 3 de 3
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
  3. Asus X55C CMOS / BIOS Battery Replacement, Optical Drive: étape 3, image 1 de 2 Asus X55C CMOS / BIOS Battery Replacement, Optical Drive: étape 3, image 2 de 2
    • Remove the screw.
    • Pull out the SATA DVD Drive.
  4. Asus X55C CMOS / BIOS Battery Replacement, Motherboard: étape 4, image 1 de 2 Asus X55C CMOS / BIOS Battery Replacement, Motherboard: étape 4, image 2 de 2
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
  5. Asus X55C CMOS / BIOS Battery Replacement: étape 5, image 1 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 5, image 2 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 5, image 3 de 3
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  6. Asus X55C CMOS / BIOS Battery Replacement: étape 6, image 1 de 2 Asus X55C CMOS / BIOS Battery Replacement: étape 6, image 2 de 2
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
  7. Asus X55C CMOS / BIOS Battery Replacement: étape 7, image 1 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 7, image 2 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 7, image 3 de 3
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
  8. Asus X55C CMOS / BIOS Battery Replacement: étape 8, image 1 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 8, image 2 de 3 Asus X55C CMOS / BIOS Battery Replacement: étape 8, image 3 de 3
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
  9. Asus X55C CMOS / BIOS Battery Replacement: étape 9, image 1 de 2 Asus X55C CMOS / BIOS Battery Replacement: étape 9, image 2 de 2
  10. Asus X55C CMOS / BIOS Battery Replacement, CMOS / BIOS Battery: étape 10, image 1 de 3 Asus X55C CMOS / BIOS Battery Replacement, CMOS / BIOS Battery: étape 10, image 2 de 3 Asus X55C CMOS / BIOS Battery Replacement, CMOS / BIOS Battery: étape 10, image 3 de 3
7 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 882 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 516 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 43
Total : 15,744
