Introduction
If your system overheating, we show you how to disassemble it, clean the Cooling system and replace the CPU Thermal paste.
_______________ Video manual: _______________
Outils
Pièces
Aucune pièce spécifiée.
Vidéo d'introduction
The Keyboard is held by 5x locking clips.
Pick up a little the one side of the Keyboard and start opening the clips one by one.
Disconnect the Keyboard flex cable from the mother board and remove the KB.
Remove 3x Philips screws.
Disconnect the two small flex cables:
Power On button flex cable
Touch pad flex cable
Disconnect:
The Microphone cable
The LCD Display flex cable
Remove 3x Pillips screws.
Lift the board first from the right edge.
There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
ASUS X55C iCore with 4GB no board RAM motherboard, model: 60-N0OMB1100
Disconnect the Fan cable from the Motherboard.
Remove the screws (4x Phillips screws) that hold the cooling system to the Motherboard
Use a lint-free cloth to clean the old thermal compound.
Use again cloth with isopropyl alcohol to clean the Thermal surface.
The Fan and Headsink are held together with a large black bar. Removing the tape at both ends, to separate the Fan from the Headsink.
Use a soft anti static brush and clean the Heatsink on the inside.
5 autre(s) ont terminé cette réparation.
