Aller au contenu principal
Asus X751L Battery Replacement
Ce dont vous avez besoin
  1. Asus X751L Battery Replacement, Keyboard: étape 1, image 1 de 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: étape 2, image 1 de 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: étape 3, image 1 de 3 Asus X751L Battery Replacement: étape 3, image 2 de 3 Asus X751L Battery Replacement: étape 3, image 3 de 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: étape 4, image 1 de 1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: étape 5, image 1 de 2 Asus X751L Battery Replacement: étape 5, image 2 de 2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: étape 6, image 1 de 3 Asus X751L Battery Replacement: étape 6, image 2 de 3 Asus X751L Battery Replacement: étape 6, image 3 de 3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
4 autres ont terminé cette réparation.
John Enderton
Membre depuis le 02/02/17
576 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 17-2, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 membres
5 tutoriels rédigés
6 commentaires
Very nice, thank you !
anh
barzamjavel - Réponse
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Réponse
Your instructions were easy to follow. Thank you!!!
theresa collet - Réponse
very helpful
khan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 13
30 derniers jours : 51
Total : 12,863
