Aller au contenu principal
Asus X751L Keyboard Replacement
Ce dont vous avez besoin
  1. Asus X751L Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Keyboard Replacement: étape 2, image 1 de 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Keyboard Replacement: étape 3, image 1 de 3 Asus X751L Keyboard Replacement: étape 3, image 2 de 3 Asus X751L Keyboard Replacement: étape 3, image 3 de 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
3 autres ont terminé cette réparation.
John Enderton
Membre depuis le 02/02/17
576 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 17-2, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 membres
5 tutoriels rédigés
Un commentaire
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 18
Total : 3,178
