Aller au contenu principal
Asus Z54C-JS31 Optical Disc Drive Replacement
Ce dont vous avez besoin
  1. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: étape 1, image 1 de 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: étape 1, image 2 de 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: étape 2, image 1 de 2 Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: étape 2, image 2 de 2
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  3. Asus Z54C-JS31 Optical Disc Drive Replacement: étape 3, image 1 de 3 Asus Z54C-JS31 Optical Disc Drive Replacement: étape 3, image 2 de 3 Asus Z54C-JS31 Optical Disc Drive Replacement: étape 3, image 3 de 3
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
  4. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: étape 4, image 1 de 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: étape 4, image 2 de 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: étape 4, image 3 de 3
    • Remove the 3mm screw with a Phillips #000 screwdriver.
    • Slide out the optical disc drive by pulling it away from the laptop.
Mark DeSimone
Membre depuis le 10/19/17
801 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 101
