Introduction
The WiFi card allows the laptop to connect to the Internet wirelessly. If you're experiencing network connection issues you may need to replace your WiFi card.
Ce dont vous avez besoin
Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
Slide the switch on the top right corner to the right.
Slide and hold the switch on the top left corner to the left and carefully remove the battery.
Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
