Aller au contenu principal
Introduction
This guide will show you how to replace an old worn out or dead battery in an Asus ZenBook UX303U laptop.
  1. Remove the two round rubber feet at the hinge-edge of the laptop.
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - Réponse
  2. Remove the eleven 4 mm Phillips #00 screws from the back panel.
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
  3. Using a plastic opening tool pry the back panel off of the laptop. Using a plastic opening tool pry the back panel off of the laptop.
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - Réponse
  4. Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool. Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
  5. Remove all seven 2 mm Phillips #00 screws from the battery. Remove all seven 2 mm Phillips #00 screws from the battery.
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Pull the speaker connector toward the edge of the laptop to disconnect it from its socket. Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
  7. Lift the battery connector straight up off its socket to disconnect it from the motherboard. Do not pry on the socket itself or you risk damaging the motherboard.
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Lift the battery and speakers up and pull out to remove. Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Remove the speakers from the old battery.
    • Remove the speakers from the old battery.
    This was a bit more fiddly than expected given the speaker arms are stuck to the battery
10 autres ont terminé cette réparation.
Dean Anderson
Membre depuis le 14/02/2018
495 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S3-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 membres
9 tutoriels rédigés
8 commentaires
hello where I can buy a UX303U battery for asus?
jeannette dreifus - Réponse
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
There are two screws holding the back panel in place. They are located below the two rubber pads at the back of the pc. They must be removed in order to open the back panel.
Dave Man - Réponse
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Barny Harper - Réponse
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - Réponse
Same here, they are really small Torx on my Asus UX303U!
Dave Taylor -
Can I use this laptop without a battery?
m khn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 70
30 derniers jours : 316
Total : 21,693
