Aller au contenu principal
Asus ZenBook UX303U Motherboard Replacement
Ce dont vous avez besoin
  1. Asus ZenBook UX303U Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - Réponse
  2. Asus ZenBook UX303U Motherboard Replacement: étape 2, image 1 de 1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - Réponse
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - Réponse
  3. Asus ZenBook UX303U Motherboard Replacement: étape 3, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 3, image 2 de 2
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - Réponse
  4. Asus ZenBook UX303U Motherboard Replacement, Battery: étape 4, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement, Battery: étape 4, image 2 de 2
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
    Skip this step on UX430U
    Styyvii - Réponse
  5. Asus ZenBook UX303U Motherboard Replacement: étape 5, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 5, image 2 de 2
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Motherboard Replacement: étape 6, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 6, image 2 de 2
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
    Skip this step on UX430U also
    Styyvii - Réponse
  7. Asus ZenBook UX303U Motherboard Replacement: étape 7, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 7, image 2 de 2
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Motherboard Replacement: étape 8, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 8, image 2 de 2
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Motherboard Replacement: étape 9, image 1 de 1
    • Remove the speakers from the old battery.
    This was a bit more fiddly than expected given the speaker arms are stuck to the battery
  10. Asus ZenBook UX303U Motherboard Replacement, Motherboard fan: étape 10, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement, Motherboard fan: étape 10, image 2 de 2
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  11. Asus ZenBook UX303U Motherboard Replacement: étape 11, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 11, image 2 de 2
    • Remove the three 6mm Phillips #00 screws from the hinge.
    • Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
  12. Asus ZenBook UX303U Motherboard Replacement: étape 12, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 12, image 2 de 2
    • Lift the bottom of the laptop up slightly in order to unhinge the laptop.
    • Lift the screen assembly hinge up and off of the motherboard fan.
  13. Asus ZenBook UX303U Motherboard Replacement: étape 13, image 1 de 3 Asus ZenBook UX303U Motherboard Replacement: étape 13, image 2 de 3 Asus ZenBook UX303U Motherboard Replacement: étape 13, image 3 de 3
    • Using tweezers, disconnect the cable connector from the motherboard fan.
  14. Asus ZenBook UX303U Motherboard Replacement: étape 14, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement: étape 14, image 2 de 2
    • Lift the fan up and off of the white pegs that secure it into place.
  15. Asus ZenBook UX303U Motherboard Replacement, Motherboard: étape 15, image 1 de 2 Asus ZenBook UX303U Motherboard Replacement, Motherboard: étape 15, image 2 de 2
    • Remove eleven 4mm Phillips #00 screws.
  16. Asus ZenBook UX303U Motherboard Replacement: étape 16, image 1 de 3 Asus ZenBook UX303U Motherboard Replacement: étape 16, image 2 de 3 Asus ZenBook UX303U Motherboard Replacement: étape 16, image 3 de 3
    • Disconnect all wires connecting the motherboard to the rest of the device.
    • For the two connectors marked in orange, lift the black clip up to release the wire.
    • For the wire marked in yellow, lift it straight up.
  17. Asus ZenBook UX303U Motherboard Replacement: étape 17, image 1 de 1
    • Lift and remove the motherboard.
    • Pull the motherboard away from the ports on the side of the device to disconnect them from the computer before lifting the motherboard.
4 autres ont terminé cette réparation.
Dean Anderson
Membre depuis le 02/14/18
621 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S3-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 membres
9 tutoriels rédigés
Un commentaire
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 24
Total : 6,330
