Aller au contenu principal
Asus ZenFone 5 Motherboard Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Asus ZenFone 5 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Heat up the iOpener in the microwave for 30 seconds.
    • Caution: when the iOpener is heated up, hold it by the sides to prevent bodily harm.
  2. Asus ZenFone 5 Motherboard Replacement: étape 2, image 1 de 1
    • Place the iOpener on the side of the phone until the iOpener gets cool (approximately 10-15 minutes).
    • Reheat the iOpener and reapply it to the other side of the phone.
  3. Asus ZenFone 5 Motherboard Replacement: étape 3, image 1 de 2 Asus ZenFone 5 Motherboard Replacement: étape 3, image 2 de 2
    • Gently slide the jimmy along the edges of the phone to break the adhesive.
    • Use opening picks and the opening tool to pry the back cover off.
    • The use of metal tools as shown in the photos is potentially dangerous as the battery is exposed along the edges of the case and risk of puncture is high. Choose an ESD safe tool instead.
    • There are 6 different tabs on each side of the phone that might take force to get apart.
    • Repeat the heating and prying process until the back cover can be fully removed.
  4. Asus ZenFone 5 Motherboard Replacement: étape 4, image 1 de 2 Asus ZenFone 5 Motherboard Replacement: étape 4, image 2 de 2
    • Use the #00 phillips head to take out the six phillips #00 3.175mm screws on the top cover plate.
    • Use the spudger to release the clasps along the edge of the top plate.
  5. Asus ZenFone 5 Motherboard Replacement: étape 5, image 1 de 1
    • Disconnect the press fit connector located near the upper right corner of the battery to disengage the battery from the motherboard.
  6. Asus ZenFone 5 Motherboard Replacement: étape 6, image 1 de 2 Asus ZenFone 5 Motherboard Replacement: étape 6, image 2 de 2
    • Use the same screwdriver to remove the five phillips #00 3.96mm screws along the bottom plate.
    • Use the spudger to pry the bottom plate off.
  7. Asus ZenFone 5 Motherboard Replacement: étape 7, image 1 de 2 Asus ZenFone 5 Motherboard Replacement: étape 7, image 2 de 2
    • Pull on the two black tabs on the bottom of the battery until the battery is released.
    • Gently pull the battery out of its socket.
  8. Asus ZenFone 5 Motherboard Replacement, Front Camera: étape 8, image 1 de 3 Asus ZenFone 5 Motherboard Replacement, Front Camera: étape 8, image 2 de 3 Asus ZenFone 5 Motherboard Replacement, Front Camera: étape 8, image 3 de 3
    • Peel off the silver tape that is to the right of the audio jack about halfway, so it is off of the silver plate.
    • Use the tweezers to disconnect the press fit connector underneath the tape, right above the silver plate.
    • Gently lift up until the camera and the connector is removed.
  9. Asus ZenFone 5 Motherboard Replacement, Motherboard: étape 9, image 1 de 3 Asus ZenFone 5 Motherboard Replacement, Motherboard: étape 9, image 2 de 3 Asus ZenFone 5 Motherboard Replacement, Motherboard: étape 9, image 3 de 3
    • Right above the battery socket, pop up the press fit connector at the end of the orange ribbon cable on the right.
    • Pry up the tab of the ZIF connector on the left to disengage the locking connector.
    • Gently pull out the ribbon cable going into the opening created by lifting the tab.
  10. Asus ZenFone 5 Motherboard Replacement: étape 10, image 1 de 3 Asus ZenFone 5 Motherboard Replacement: étape 10, image 2 de 3 Asus ZenFone 5 Motherboard Replacement: étape 10, image 3 de 3
    • Pull the tab that is located to the left of the camera button, adjacent to the volume up button.
    • Pull out the gold headed coaxial cable on the bottom right of the motherboard.
    • Use the screwdriver to take out the one Phillips #00 head 3.175mm screw located directly to the right of the silver plate.
  11. Asus ZenFone 5 Motherboard Replacement: étape 11, image 1 de 3 Asus ZenFone 5 Motherboard Replacement: étape 11, image 2 de 3 Asus ZenFone 5 Motherboard Replacement: étape 11, image 3 de 3
    • Pry off the tab to the right of the camera.
    • Use the spudger to pry off the motherboard around its edges.
    • The motherboard is brittle, so it can break if too much force is used.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,634
