Aller au contenu principal
Asus ZenWatch 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
  2. Asus ZenWatch 2 Motherboard Replacement: étape 2, image 1 de 2 Asus ZenWatch 2 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the two 1.8mm silver screws using the PH00 screwdriver.
  3. Asus ZenWatch 2 Motherboard Replacement: étape 3, image 1 de 2 Asus ZenWatch 2 Motherboard Replacement: étape 3, image 2 de 2
    • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
  4. Asus ZenWatch 2 Motherboard Replacement: étape 4, image 1 de 2 Asus ZenWatch 2 Motherboard Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Pull up on the motherboard using tweezers to detach it from the watch.
Andrew
Membre depuis le 02/20/17
314 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Spring 2017 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 membres
10 tutoriels rédigés
6 commentaires
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - Réponse
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - Réponse
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard -
Where can you purchase a replacement motherboard?
Tasha Kanahele - Réponse
My zenfone wach 2 all function not showing please help me
Akhtar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 16
Total : 2,621
