Aller au contenu principal
Asus Zenbook UX21e Battery Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX21e Battery Replacement, Battery: étape 1, image 1 de 3 Asus Zenbook UX21e Battery Replacement, Battery: étape 1, image 2 de 3 Asus Zenbook UX21e Battery Replacement, Battery: étape 1, image 3 de 3
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  2. Asus Zenbook UX21e Battery Replacement: étape 2, image 1 de 3 Asus Zenbook UX21e Battery Replacement: étape 2, image 2 de 3 Asus Zenbook UX21e Battery Replacement: étape 2, image 3 de 3
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
  3. Asus Zenbook UX21e Battery Replacement: étape 3, image 1 de 1
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
  4. Asus Zenbook UX21e Battery Replacement: étape 4, image 1 de 2 Asus Zenbook UX21e Battery Replacement: étape 4, image 2 de 2
    • Lift the battery directly up and remove it from the device.
4 autres ont terminé cette réparation.
Zachary Eslick
Membre depuis le 04/23/18
756 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S22-G1, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S22-G1, Maness Spring 2018
CPSU-MANESS-S18S22G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 18
Total : 4,013
