Aller au contenu principal
Asus Zenbook UX303L Cooling Fan Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: étape 1, image 1 de 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: étape 2, image 1 de 3 Asus Zenbook UX303L Cooling Fan Replacement: étape 2, image 2 de 3 Asus Zenbook UX303L Cooling Fan Replacement: étape 2, image 3 de 3
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: étape 3, image 1 de 2 Asus Zenbook UX303L Cooling Fan Replacement: étape 3, image 2 de 2
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: étape 4, image 1 de 3 Asus Zenbook UX303L Cooling Fan Replacement: étape 4, image 2 de 3 Asus Zenbook UX303L Cooling Fan Replacement: étape 4, image 3 de 3
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: étape 5, image 1 de 3 Asus Zenbook UX303L Cooling Fan Replacement: étape 5, image 2 de 3 Asus Zenbook UX303L Cooling Fan Replacement: étape 5, image 3 de 3
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: étape 6, image 1 de 2 Asus Zenbook UX303L Cooling Fan Replacement: étape 6, image 2 de 2
    • Gently lift and slide the cooling fan out.
4 autres ont terminé cette réparation.
Bianka Castaneda
Membre depuis le 10/13/15
469 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-3, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-3, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G3
3 membres
4 tutoriels rédigés
3 commentaires
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - Réponse
I wish you guys had included the part number for the cooling fan.
mhyson - Réponse
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 23
Total : 6,170
