Aller au contenu principal
Asus Zenbook UX303L Speaker Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: étape 2, image 1 de 1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: étape 3, image 1 de 1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: étape 4, image 1 de 1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: étape 5, image 1 de 1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: étape 6, image 1 de 1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: étape 7, image 1 de 1
    • Carefully peel away the defective speakers from the battery.
Ryan Snow
Membre depuis le 04/01/19
200 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G6, Harley Spring 2019 Membre de l'équipe IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 membres
7 tutoriels rédigés
Un commentaire
Is the Asus UX303L same as U303L?
Michael Wolf - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 9
30 derniers jours : 22
Total : 1,746
