Aller au contenu principal
Asus Zenbook UX303L Trackpad Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX303L Trackpad Replacement, Trackpad: étape 1, image 1 de 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Trackpad Replacement: étape 2, image 1 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 2, image 2 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 2, image 3 de 3
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Trackpad Replacement: étape 3, image 1 de 1
    • Remove five Phillips #1 screws from the battery pack.
  4. Asus Zenbook UX303L Trackpad Replacement: étape 4, image 1 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 4, image 2 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 4, image 3 de 3
    • Unhook the red, black, and white coiled switch.
    • Detach the positive and negative red, black, yellow, and white switch from the motherboard.
    • Unhook the black and white coiled wire from the top of the battery pack.
  5. Asus Zenbook UX303L Trackpad Replacement: étape 5, image 1 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 5, image 2 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 5, image 3 de 3
    • Remove the three screws connecting the SSD to the motherboard.
    • Gently lift and pull out the SSD.
  6. Asus Zenbook UX303L Trackpad Replacement: étape 6, image 1 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 6, image 2 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 6, image 3 de 3
    • Remove the screw attaching the cooling fan to the motherboard.
    • Lift and remove the cooling fan.
  7. Asus Zenbook UX303L Trackpad Replacement: étape 7, image 1 de 2 Asus Zenbook UX303L Trackpad Replacement: étape 7, image 2 de 2
    • Remove the four Phillips #1 screws attached to the black covered copper bar next to the cooling fan.
    • Gently lift and remove the copper bar.
  8. Asus Zenbook UX303L Trackpad Replacement: étape 8, image 1 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 8, image 2 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 8, image 3 de 3
    • Remove the silver tape to reveal the fourth screw on the motherboard.
    • Detach the motherboard by removing the four Phillips #1 screws.
    • Detach the white wire connecting the motherboard by lifting the black flap and pulling it out.
  9. Asus Zenbook UX303L Trackpad Replacement: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • By using ESD-safe tweezers, remove the gray colored wire.
    • Remove the white wire using tweezers.
    • Remove the blue colored wire by lifting the black flap and pulling the blue flap out.
  10. Asus Zenbook UX303L Trackpad Replacement: étape 10, image 1 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 10, image 2 de 3 Asus Zenbook UX303L Trackpad Replacement: étape 10, image 3 de 3
    • Remove the white wire with the blue ends by lifting the black flap with tweezers and gently pulling out.
    • Gently remove the silver tape using tweezers.
    • Remove the Phillips #1 screws.
  11. Asus Zenbook UX303L Trackpad Replacement: étape 11, image 1 de 2 Asus Zenbook UX303L Trackpad Replacement: étape 11, image 2 de 2
    • Place the plastic opening tools under the trackpad.
    • Gently pull out and remove the trackpad.
3 autres ont terminé cette réparation.
Fredis Benitez
Membre depuis le 10/13/15
259 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-3, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-3, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G3
3 membres
4 tutoriels rédigés
Un commentaire
This laptop comes with a very bad trackpad, it has very low resolution. Do you think it can be updated?
eduugr - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 25
Total : 5,953
