Aller au contenu principal
Asus Zenbook UX31A Daughterboard Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX31A Daughterboard Replacement, Battery: étape 1, image 1 de 2 Asus Zenbook UX31A Daughterboard Replacement, Battery: étape 1, image 2 de 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Daughterboard Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Daughterboard Replacement: étape 3, image 1 de 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Daughterboard Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Daughterboard Replacement, Fan: étape 5, image 1 de 2 Asus Zenbook UX31A Daughterboard Replacement, Fan: étape 5, image 2 de 2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Daughterboard Replacement: étape 6, image 1 de 3 Asus Zenbook UX31A Daughterboard Replacement: étape 6, image 2 de 3 Asus Zenbook UX31A Daughterboard Replacement: étape 6, image 3 de 3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Daughterboard Replacement: étape 7, image 1 de 2 Asus Zenbook UX31A Daughterboard Replacement: étape 7, image 2 de 2
    • Disconnect the fan connector by puling on it horizontally until it disconnects.
    • Remove the fan.
  8. Asus Zenbook UX31A Daughterboard Replacement, Daughterboard: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to detach the cable from the board by pulling them gently toward the bottom edge of the board.
  9. Asus Zenbook UX31A Daughterboard Replacement: étape 9, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 6 mm screw that secures the daughterboard.
  10. Asus Zenbook UX31A Daughterboard Replacement: étape 10, image 1 de 1
    • Remove by carefully lifting the board from the laptop.
Sherwin
Membre depuis le 03/22/22
209 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 173
