Aller au contenu principal
Asus Zenbook UX31A Touchpad Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX31A Touchpad Replacement, Battery: étape 1, image 1 de 2 Asus Zenbook UX31A Touchpad Replacement, Battery: étape 1, image 2 de 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Touchpad Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Touchpad Replacement: étape 3, image 1 de 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Touchpad Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Touchpad Replacement, Touchpad: étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to remove all four 6 mm screws from the trackpad.
  6. Asus Zenbook UX31A Touchpad Replacement: étape 6, image 1 de 1
    • Use your fingers or a nylon spuder to gently lift the track pad ZIF tab, and pull the ribbon cable free.
    • Be gentle with this wire since it is fragile
  7. Asus Zenbook UX31A Touchpad Replacement: étape 7, image 1 de 1
    • Lift up and pull backwards to remove the touchpad
Christopoher Orser
Membre depuis le 03/22/22
294 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 32
Total : 585
