Aller au contenu principal
Asus Zenbook UX31A Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 1 de 2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 2 de 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: étape 2, image 1 de 2 Asus Zenbook UX31A Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Sherwin
Membre depuis le 03/22/22
209 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 21
Total : 287
