Introduction
If you have found that your Asus Zenbook UX31E is refusing to charge upon plugging it into the adapter or your screen is flickering upon usage of the adapter your problem may be with the charging port.
The charging port acts as a lifeline between the power outlet and the battery of your Zenbook, it is necessary to ensure a safe replacement of the charging port if and when needed to avoid further issues with the life of your Zenbook.
If your Zenbook is able to connect to your adapter when plugged in but is not holding a charge, your issue may be with the battery instead.
As with all electronic repairs, your Zenbook should be powered off completely and not plugged into any power sources.
Ce dont vous avez besoin
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
Outil utilisé dans cette étape :Tweezers$4.99
Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
Remove the press fit connector attaching the motherboard to the screen.
Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
Flip the motherboard over so that the topside is facing up.
Use a soldering iron to heat up the four solder points surrounding the charging port.
Click here to see how to use a Soldering iron on a motherboard without a heat gun
2 autres ont terminé cette réparation.
