Aller au contenu principal
Asus Zenbook UX31E LCD Screen Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX31E LCD Screen Replacement, Back Cover: étape 1, image 1 de 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E LCD Screen Replacement: étape 2, image 1 de 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E LCD Screen Replacement, Battery: étape 3, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E LCD Screen Replacement: étape 4, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 4, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E LCD Screen Replacement: étape 5, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 5, image 2 de 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
  6. Asus Zenbook UX31E LCD Screen Replacement, Speaker: étape 6, image 1 de 1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  7. Asus Zenbook UX31E LCD Screen Replacement: étape 7, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 7, image 2 de 2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  8. Asus Zenbook UX31E LCD Screen Replacement: étape 8, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 8, image 2 de 2
    • Disconnect the sound cable from the motherboard.
  9. Asus Zenbook UX31E LCD Screen Replacement: étape 9, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 9, image 2 de 2
    • Using the plastic opening tool, pry open the speaker component from the computer.
  10. Asus Zenbook UX31E LCD Screen Replacement, SSD: étape 10, image 1 de 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  11. Asus Zenbook UX31E LCD Screen Replacement: étape 11, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 11, image 2 de 2
    • Using your hand, pull the SSD out from its slot.
  12. Asus Zenbook UX31E LCD Screen Replacement, Fan: étape 12, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement, Fan: étape 12, image 2 de 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  13. Asus Zenbook UX31E LCD Screen Replacement: étape 13, image 1 de 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  14. Asus Zenbook UX31E LCD Screen Replacement: étape 14, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 14, image 2 de 2
    • Unscrew the two screws that are across each other.
  15. Asus Zenbook UX31E LCD Screen Replacement: étape 15, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 15, image 2 de 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
  16. Asus Zenbook UX31E LCD Screen Replacement, LCD Screen: étape 16, image 1 de 1
    • Although replacement guides are listed as prerequisites, they are mainly used for disassembly.
    • At the marked locations, unscrew 7 screws with your Phillips 00 Precision Screwdriver.
    • At the marked locations (under certain components), unscrew 3 screws with your Phillips 00 Precision Screwdriver.
  17. Asus Zenbook UX31E LCD Screen Replacement: étape 17, image 1 de 1
    • Carefully pull out the ribbon connecting your keyboard and motherboard from the motherboard.
    • This is a very delicate component, so do handle it with care.
  18. Asus Zenbook UX31E LCD Screen Replacement: étape 18, image 1 de 1
    • At the bottom right corner of your laptop, carefully pull the connector from its socket.
  19. Asus Zenbook UX31E LCD Screen Replacement: étape 19, image 1 de 2 Asus Zenbook UX31E LCD Screen Replacement: étape 19, image 2 de 2
    • Carefully pull the black wire with a copper connector out from its socket.
    • Carefully pull the white wire with a copper connector out from its socket.
    • When reassembling, you will hear a pop when connecting these back.
  20. Asus Zenbook UX31E LCD Screen Replacement: étape 20, image 1 de 1
    • Carefully unplug this white wire from the motherboard
  21. Asus Zenbook UX31E LCD Screen Replacement: étape 21, image 1 de 1
    • At the corners between your screen and the rest of your laptop, unscrew 4 screws with your Phillips 00 Precision Screwdrivers.
  22. Asus Zenbook UX31E LCD Screen Replacement: étape 22, image 1 de 1
    • Slide the display to either the left or right to loosen it.
    • Pull the display away from the rest of your laptop.
5 autres ont terminé cette réparation.
Charles Jackson
Membre depuis le 02/02/17
668 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team 1-2, Rose Winter 2017 Membre de l'équipe UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 23
Total : 8,707
