Ce dont vous avez besoin
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
At the marked locations, unscrew 7 screws with your Phillips 00 Precision Screwdriver.
At the marked locations (under certain components), unscrew 3 screws with your Phillips 00 Precision Screwdriver.
5 autres ont terminé cette réparation.
