Aller au contenu principal
Asus Zenbook UX31E Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX31E Motherboard  Replacement, Back Cover: étape 1, image 1 de 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Motherboard  Replacement: étape 2, image 1 de 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Motherboard  Replacement, Speaker: étape 3, image 1 de 1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Asus Zenbook UX31E Motherboard  Replacement: étape 4, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 4, image 2 de 2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Asus Zenbook UX31E Motherboard  Replacement: étape 5, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 5, image 2 de 2
    • Disconnect the sound cable from the motherboard.
  6. Asus Zenbook UX31E Motherboard  Replacement: étape 6, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 6, image 2 de 2
    • Using the plastic opening tool, pry open the speaker component from the computer.
  7. Asus Zenbook UX31E Motherboard  Replacement, Battery: étape 7, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement, Battery: étape 7, image 2 de 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  8. Asus Zenbook UX31E Motherboard  Replacement: étape 8, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 8, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  9. Asus Zenbook UX31E Motherboard  Replacement: étape 9, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 9, image 2 de 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
  10. Asus Zenbook UX31E Motherboard  Replacement, SSD: étape 10, image 1 de 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  11. Asus Zenbook UX31E Motherboard  Replacement: étape 11, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 11, image 2 de 2
    • Using your hand, pull the SSD out from its slot.
  12. Asus Zenbook UX31E Motherboard  Replacement, Fan: étape 12, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement, Fan: étape 12, image 2 de 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  13. Asus Zenbook UX31E Motherboard  Replacement: étape 13, image 1 de 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  14. Asus Zenbook UX31E Motherboard  Replacement: étape 14, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 14, image 2 de 2
    • Unscrew the two screws that are across each other.
  15. Asus Zenbook UX31E Motherboard  Replacement: étape 15, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 15, image 2 de 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
  16. Asus Zenbook UX31E Motherboard  Replacement, Motherboard: étape 16, image 1 de 3 Asus Zenbook UX31E Motherboard  Replacement, Motherboard: étape 16, image 2 de 3 Asus Zenbook UX31E Motherboard  Replacement, Motherboard: étape 16, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
    • Remove the press fit connector attaching the motherboard to the screen.
    • Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
  17. Asus Zenbook UX31E Motherboard  Replacement: étape 17, image 1 de 2 Asus Zenbook UX31E Motherboard  Replacement: étape 17, image 2 de 2
    • Lift gently and flip the motherboard over in the direction of the track pad.
    • Peel off the the yellow tape.
    • Detach the ZIF connector on the underside of the motherboard connecting it to the keyboard.
    • Remove the motherboard.
Un commentaire
Boa Tarde
Tenho um equipamento igual não está apresentando imagen no LCD fica o power e caps look ligado e apenas arranca o cooller nada mais
renatoxornelas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 1,741
