Aller au contenu principal
Asus Zenbook UX32VD HD Web Camera Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: étape 1, image 1 de 1
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: étape 2, image 1 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 2, image 2 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Metal Spudger Set
    $7.99
    J'achète
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: étape 3, image 1 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 3, image 2 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 3, image 3 de 3
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: étape 4, image 1 de 2 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 4, image 2 de 2
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: étape 5, image 1 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 5, image 2 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: étape 5, image 3 de 3
    Spudger
    $2.99
    J'achète
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
Michael Remmel
Membre depuis le 09/17/15
709 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 membres
6 tutoriels rédigés
2 commentaires
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Réponse
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 1,860
