Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to replace noisy or malfunctioning GPU fan in the Asus Zenbook UX32VD.
Pièces
Aucune pièce spécifiée.
  1. Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed. Remove the bottom panel from the body of the laptop. Set aside the bottom panel.
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
    • Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
    • Be sure to pry up on the hinged retaining flap, not the connector itself.
    • Remove the metallic ribbon cable from the connector .
    • No force is needed to remove or insert the cable.
  2. Remove the 3 (4mm) fan screws with a  Phillips #0 Screwdriver Remove the 3 (4mm) fan screws with a  Phillips #0 Screwdriver Remove the 3 (4mm) fan screws with a  Phillips #0 Screwdriver
  3. Unplug the bundled cable connector. Move the fan as shown in the first picture to better access the connector. Pull the cable away from the connector in the same direction as the individual wires are running.
    • Unplug the bundled cable connector.
    • Move the fan as shown in the first picture to better access the connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  4. Remove the fan completely.
    • Remove the fan completely.
Miguel Angel Felix
Membre depuis le 17/09/2015
110 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,655
