Aller au contenu principal
Asus Zenbook UX32VD Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: étape 1, image 1 de 3 Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: étape 1, image 2 de 3 Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    T5 Torx Screwdriver
    $9.99
    J'achète
  2. Asus Zenbook UX32VD Hard Drive Replacement: étape 2, image 1 de 3 Asus Zenbook UX32VD Hard Drive Replacement: étape 2, image 2 de 3 Asus Zenbook UX32VD Hard Drive Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Hard Drive Replacement, Battery: étape 3, image 1 de 2 Asus Zenbook UX32VD Hard Drive Replacement, Battery: étape 3, image 2 de 2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Hard Drive Replacement: étape 4, image 1 de 2 Asus Zenbook UX32VD Hard Drive Replacement: étape 4, image 2 de 2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Hard Drive Replacement: étape 5, image 1 de 3 Asus Zenbook UX32VD Hard Drive Replacement: étape 5, image 2 de 3 Asus Zenbook UX32VD Hard Drive Replacement: étape 5, image 3 de 3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the battery completely.
  7. Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: étape 7, image 1 de 3 Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: étape 7, image 2 de 3 Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: étape 7, image 3 de 3
    Phillips #0 Screwdriver
    $5.49
    J'achète
  8. Asus Zenbook UX32VD Hard Drive Replacement: étape 8, image 1 de 3 Asus Zenbook UX32VD Hard Drive Replacement: étape 8, image 2 de 3 Asus Zenbook UX32VD Hard Drive Replacement: étape 8, image 3 de 3
    • Lift the hard drive slightly and gently pull the hard drive from the socket.
    • Do not lift the hard drive too high. Doing so could damage the hard drive or other internal components of the laptop.
    • Remove the hard drive completely.
12 autres ont terminé cette réparation.
Michael Remmel
Membre depuis le 09/17/15
709 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 membres
6 tutoriels rédigés
4 commentaires
Installed a new WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s 2.5"/7mm Solid State Drive into my UX32VD using this guide. It works like charm! Thanks for the guide
Le Zap - Réponse
Excellent! Precise and concise to the point!Thank you!
Android Phone - Réponse
Exzellent Guide, Thank you so much!
sina - Réponse
can someone confirm to me that samsung evo 860 will work or not for this asus please
Karim Othman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 28
Total : 10,812
