Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
  • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
  • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
Ajouter un commentaire
Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
  • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
  • Realign the buttons over the sensors/clean the sensor contacts.
  • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
  • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
  • Use a spudger to remove the top frame.
  • Take off the plate.
  • Remove the rubber buttons.
  • Pull the circuit strip through the new space.
  • Realign the top and bottom of the controller.
  • Return the buttons to the top of the controller.
  • Snap the frame back into place.
  • Screw the screws.
Alan Abelson
Membre depuis le 26/09/2014
230 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 13-1, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 486
