Introduction
If the button on an Atari Flashback 2 joystick is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the joystick in order to access the button to do so efficiently.
Ce dont vous avez besoin
Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
Remove the bottom panel from the joystick.
Presque terminé !
