Introduction
Before starting this guide you may need some experience with soldering/ desoldering. If you do not know how, you can learn by clicking the link on step 5 (when you have to desolder the wires).
  1. Before disassembling your Atari Lynx, be sure the device is powered off.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  5. Remove the control panel by pinching the sides with your fingers and lifting  it away from the Atari.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  6. Desolder both the black and red wire as shown.
    • Desolder both the black and red wire as shown.
    • If you need help with basic desoldering, click here.
  7. Desolder the black wire as shown.
    • Desolder the black wire as shown.
  8. Desolder the white wire and then the red wire as shown. Desolder the white wire and then the red wire as shown.
    • Desolder the white wire and then the red wire as shown.
  9. Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
    • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
John Lopez
Membre depuis le 27/01/2014
440 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 1-42, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 membres
8 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 15
Total : 961
