Aller au contenu principal
Atmega328P Microcontroller Replacement for Arduino Board
Ce dont vous avez besoin
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: étape 1, image 1 de 1
    • Place the Arduino UNO R3 board on a flat clean surface.
  2. Atmega328P Microcontroller Replacement for Arduino Board: étape 2, image 1 de 2 Atmega328P Microcontroller Replacement for Arduino Board: étape 2, image 2 de 2
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
  3. Atmega328P Microcontroller Replacement for Arduino Board: étape 3, image 1 de 2 Atmega328P Microcontroller Replacement for Arduino Board: étape 3, image 2 de 2
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
  4. Atmega328P Microcontroller Replacement for Arduino Board: étape 4, image 1 de 3 Atmega328P Microcontroller Replacement for Arduino Board: étape 4, image 2 de 3 Atmega328P Microcontroller Replacement for Arduino Board: étape 4, image 3 de 3
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
  5. Atmega328P Microcontroller Replacement for Arduino Board: étape 5, image 1 de 1
    • Remove replacement microcontroller out of packaging.
  6. Atmega328P Microcontroller Replacement for Arduino Board: étape 6, image 1 de 1
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
  7. Atmega328P Microcontroller Replacement for Arduino Board: étape 7, image 1 de 2 Atmega328P Microcontroller Replacement for Arduino Board: étape 7, image 2 de 2
    • Gently press the microcontroller into the dip socket
2 autres ont terminé cette réparation.
Youssef Qteshat
Membre depuis le 01/26/23
193 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 5-5, Morris Winter 2023 Membre de l'équipe UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 36
Total : 352
