Aller au contenu principal
Audio Technica ATH-AD500 Driver Replacement
Ce dont vous avez besoin
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: étape 1, image 1 de 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: étape 2, image 1 de 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: étape 3, image 1 de 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: étape 4, image 1 de 1
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: étape 5, image 1 de 1
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: étape 6, image 1 de 2 Audio Technica ATH-AD500 Driver Replacement: étape 6, image 2 de 2
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Comment souder et dessouder des connexions.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: étape 7, image 1 de 2 Audio Technica ATH-AD500 Driver Replacement: étape 7, image 2 de 2
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
2 autres ont terminé cette réparation.
Nick Levy
Membre depuis le 01/13/13
177 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-19, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 membres
17 tutoriels rédigés
2 commentaires
where can i buy a replacement driver?
acidxgangster - Réponse
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 41
Total : 10,872
