Aller au contenu principal
Audio Technica ATH-AD500 Left Headphone Cable Replacement
Ce dont vous avez besoin
  1. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Speaker Assembly: étape 1, image 1 de 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 2, image 1 de 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 3, image 1 de 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: étape 4, image 1 de 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: étape 4, image 2 de 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: étape 4, image 3 de 3
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference Comment souder et dessouder des connexions.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 5, image 1 de 2 Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 5, image 2 de 2
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
  6. Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 6, image 1 de 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 6, image 2 de 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: étape 6, image 3 de 3
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference Comment souder et dessouder des connexions.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
3 autres ont terminé cette réparation.
Melanie Reis
Membre depuis le 01/11/13
227 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 17-19, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 membres
17 tutoriels rédigés
2 commentaires
Thank you so much! your guide helped me repair my AD900x!
Anwar X - Réponse
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 20
30 derniers jours : 108
Total : 9,266
