Aller au contenu principal
Audio-Technica AT-LP60BK-BT Belt Drive Replacement
Ce dont vous avez besoin
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: étape 1, image 1 de 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: étape 1, image 2 de 2
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 2, image 1 de 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 2, image 2 de 2
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 3, image 1 de 1
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 4, image 1 de 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 4, image 2 de 2
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 5, image 1 de 1
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 6, image 1 de 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 6, image 2 de 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 6, image 3 de 3
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 7, image 1 de 1
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 8, image 1 de 1
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 9, image 1 de 1
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 10, image 1 de 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 10, image 2 de 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: étape 10, image 3 de 3
    • Test the function by spinning the platter and put the rubber mat into place.
Zonghao Li
Membre depuis le 01/20/21
208 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G15, Melo-Thaiss Winter 2021 Membre de l'équipe York University, Team S1-G15, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G15
1 membre
1 tutoriel rédigé
Un commentaire
Thank you so much!
Joe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 160
30 derniers jours : 687
Total : 8,004
