Introduction
This guide will teach you how to replace the gears that are located within the device. The gears can malfunction causing issues with the rotating of the lock.
Ce dont vous avez besoin
Flip the device over so the metal plate is facing you.
Undo the latches on the side to remove the metal plate.
Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
11 autres ont terminé cette réparation.
6 commentaires
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
