Aller au contenu principal
August Smart Lock Speaker Replacement
Ce dont vous avez besoin
  1. August Smart Lock Speaker Replacement, Speaker: étape 1, image 1 de 3 August Smart Lock Speaker Replacement, Speaker: étape 1, image 2 de 3 August Smart Lock Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Speaker Replacement: étape 2, image 1 de 3 August Smart Lock Speaker Replacement: étape 2, image 2 de 3 August Smart Lock Speaker Replacement: étape 2, image 3 de 3
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
  3. August Smart Lock Speaker Replacement: étape 3, image 1 de 3 August Smart Lock Speaker Replacement: étape 3, image 2 de 3 August Smart Lock Speaker Replacement: étape 3, image 3 de 3
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
  4. August Smart Lock Speaker Replacement: étape 4, image 1 de 2 August Smart Lock Speaker Replacement: étape 4, image 2 de 2
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
William Fink
Membre depuis le 09/26/17
766 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S11-G6, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 8
Total : 1,448
