Aller au contenu principal
Automatic Tommy 20 Ammo Drum Replacement
Ce dont vous avez besoin
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: étape 1, image 1 de 2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: étape 1, image 2 de 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: étape 2, image 1 de 3 Automatic Tommy 20 Ammo Drum Replacement: étape 2, image 2 de 3 Automatic Tommy 20 Ammo Drum Replacement: étape 2, image 3 de 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: étape 3, image 1 de 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: étape 3, image 2 de 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: étape 3, image 3 de 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: étape 4, image 1 de 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
3 autres ont terminé cette réparation.
Moira Foster
Membre depuis le 10/09/14
419 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-22, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 773
