Aller au contenu principal
Automatic Tommy 20 Dart Accelerator Replacement
Ce dont vous avez besoin
  1. Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: étape 1, image 1 de 2 Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: étape 1, image 2 de 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Dart Accelerator Replacement: étape 2, image 1 de 3 Automatic Tommy 20 Dart Accelerator Replacement: étape 2, image 2 de 3 Automatic Tommy 20 Dart Accelerator Replacement: étape 2, image 3 de 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: étape 3, image 1 de 3 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: étape 3, image 2 de 3 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: étape 3, image 3 de 3
    • Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
    • Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
  4. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Bushing: étape 4, image 1 de 1
    • Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
    • Remove the bushing by simply pulling it away from the plastic.
  5. Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: étape 5, image 1 de 2 Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: étape 5, image 2 de 2
    • Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver
  6. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Accelerator: étape 6, image 1 de 1
    • Pull back on the accelerator away from the plastic to remove from frame.
    • Be careful to not pull too quickly or too hard to avoid damaging the wiring.
3 autres ont terminé cette réparation.
Reed Garmsen
Membre depuis le 10/07/14
468 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-22, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 6
Total : 1,116
