Aller au contenu principal
Automatic Tommy 20 Trigger Spring Replacement
Ce dont vous avez besoin
  1. Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: étape 1, image 1 de 2 Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: étape 1, image 2 de 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Trigger Spring Replacement: étape 2, image 1 de 3 Automatic Tommy 20 Trigger Spring Replacement: étape 2, image 2 de 3 Automatic Tommy 20 Trigger Spring Replacement: étape 2, image 3 de 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: étape 3, image 1 de 3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: étape 3, image 2 de 3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: étape 3, image 3 de 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Trigger Spring Replacement: étape 4, image 1 de 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
  5. Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: étape 5, image 1 de 2 Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: étape 5, image 2 de 2
    • Grab both sides of the gun and pull forcefully in an upward and outward motion to remove from the light green stock.
    • If this is your first time disassembling your gun, the stock will be glued to each half of the gun's body. To break off the stock from the frame of the gun, you will need to careful wiggle the two halves so that the glue will break apart. The plastic on the gun may break or warp slightly.
  6. Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: étape 6, image 1 de 2 Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: étape 6, image 2 de 2
    • Remove the two 1/16 in. screws attaching the battery box to the frame of the gun using a Phillips #00 Screwdriver.
    • Lift the battery box off the frame of the gun to give yourself access to the trigger mechanism.
  7. Automatic Tommy 20 Trigger Spring Replacement, Removing the Screws from the Trigger Mechanism: étape 7, image 1 de 1
    • Remove the two 1/6 in. screws connecting the trigger and trigger spring to the frame of the gun using a Phillips #00 Screwdriver.
  8. Automatic Tommy 20 Trigger Spring Replacement: étape 8, image 1 de 2 Automatic Tommy 20 Trigger Spring Replacement: étape 8, image 2 de 2
    • Lift the plastic trigger away from the gun along with the attached spring.
    • Make sure you do not lift the trigger without the spring or the spring may stretch and no longer function properly.
2 autres ont terminé cette réparation.
Moira Foster
Membre depuis le 10/09/14
419 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-22, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 15
Total : 854
