Aller au contenu principal
Autosampler Installation Procedure (For Old Version)
  1. Autosampler Installation Procedure (For Old Version), Preparing before heading into the field: étape 1, image 1 de 3 Autosampler Installation Procedure (For Old Version), Preparing before heading into the field: étape 1, image 2 de 3 Autosampler Installation Procedure (For Old Version), Preparing before heading into the field: étape 1, image 3 de 3
    • 1. Ensure the autosampler wire and autosampler battery wire are threaded through the conduit before heading to the field.
    • 2. Clean and prepare bottles and tubing prior to heading to the field.
    • 3. Charge and check battery levels of a node battery and an autosampler battery prior to heading to the field. See this tutorial for more details.
    • Go through the autosampler field installation checklist to ensure you have all the tools before heading into the field!
  2. Autosampler Installation Procedure (For Old Version), rewiring the node: étape 2, image 1 de 3 Autosampler Installation Procedure (For Old Version), rewiring the node: étape 2, image 2 de 3 Autosampler Installation Procedure (For Old Version), rewiring the node: étape 2, image 3 de 3
    • 4. Connect conduit to the node.
    • 5. Rewire the node. See this tutorial for more detail.
    • Confirm no exposed wires are touching or else you could short the circuit!
    • 6. Reconnect the 6-pin autosampler connector.
  3. Autosampler Installation Procedure (For Old Version), connecting all the components: étape 3, image 1 de 3 Autosampler Installation Procedure (For Old Version), connecting all the components: étape 3, image 2 de 3 Autosampler Installation Procedure (For Old Version), connecting all the components: étape 3, image 3 de 3
    • 7. Reconnect the 2-pin autosampler battery to the autosampler.
    • 8. Reconnect the grey battery connector from the autosampler to the node.
    • 9. Reconnect the lithium ion battery in the node.
  4. Autosampler Installation Procedure (For Old Version), configure and program autosampler: étape 4, image 1 de 2 Autosampler Installation Procedure (For Old Version), configure and program autosampler: étape 4, image 2 de 2
    • 10. Secure solar charge controller to the side of the enclosure using velcro.
    • Then plug in the solar charger last.
    • 11. Flip the autosampler battery switch away from the enclosure edge to turn it on. Confirm the autosampler is correctly configured. See this tutorial for configuring. Confirm the autosampler is correctly programmed. See this tutorial for programming.
  5. Autosampler Installation Procedure (For Old Version), setting sample bottle number: étape 5, image 1 de 3 Autosampler Installation Procedure (For Old Version), setting sample bottle number: étape 5, image 2 de 3 Autosampler Installation Procedure (For Old Version), setting sample bottle number: étape 5, image 3 de 3
    • Press Start Sampling
    • Press Enter
    • Press the number of the bottle you want to sample on and then Press Enter
  6. Autosampler Installation Procedure (For Old Version), put autosampler in "node trigger mode": étape 6, image 1 de 3 Autosampler Installation Procedure (For Old Version), put autosampler in "node trigger mode": étape 6, image 2 de 3 Autosampler Installation Procedure (For Old Version), put autosampler in "node trigger mode": étape 6, image 3 de 3
    • LCD should now show which bottle it will take a sample in
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
  7. Autosampler Installation Procedure (For Old Version), trigger the sampler: étape 7, image 1 de 1
    • Trigger a sample on the appropriate site website.
    • If you see N/A on the status for a node this means our server is down. Contact the lab to reset the server! There is a variable called `sleeptimer_mode`, that will need set to "manual" instead of "auto".
  8. Autosampler Installation Procedure (For Old Version), connect tubing: étape 8, image 1 de 2 Autosampler Installation Procedure (For Old Version), connect tubing: étape 8, image 2 de 2
    • 13. Once the autosampler triggers correctly, connect the autosampler tubing to the the autosampler with a barb connector. Place the autosampler tubing into the water.
    • 14. Secure the wiring on the autosampler.
  9. Autosampler Installation Procedure (For Old Version), secure the autosampler: étape 9, image 1 de 3 Autosampler Installation Procedure (For Old Version), secure the autosampler: étape 9, image 2 de 3 Autosampler Installation Procedure (For Old Version), secure the autosampler: étape 9, image 3 de 3
    • 15. Place the autosampler lid back the autosampler.
    • 16. Secure the autosampler.
    • 17. This is what a completed site looks like.
Ligne d'arrivée
Brooke Mason
Membre depuis le 05/29/19
2 958 Réputation
17 tutoriels rédigés
Équipe
Open-Storm Membre de l'équipe Open-Storm
Community
14 membres
24 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 396
